[Mapguide-trac] [mapguide-trac] #2495: Disable GCC variable tracking when compiling PHP/Java wrappers
MapGuide Open Source trac_mapguide at osgeo.org
Sun Oct 19 04:33:58 PDT 2014
   Reporter:  jng           |       Owner:  jng
       Type:  task          |      Status:  new
   Priority:  low           |   Milestone:  3.0
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 When compiling the PHP and Java wrappers, the following message is shown
 every time.
 note: variable tracking size limit exceeded with -fvar-tracking-
 assignments, retrying without
 Since it seems that VTA will never work for these projects, there's no
 point wasting time trying to build these projects with settings that will
 never work which will require a subsequent re-build without said settings,
 we should apply this flag for such projects:
 -fno-var-tracking-assignments
 Which will skip this time-wasting step.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2495>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
