[Mapguide-trac] [mapguide-trac] #2497: Avoid bash-isms in mapguide service/run/install scripts
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 21 07:14:50 PDT 2014
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  3.0
  Component:  General  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Although bash is required to be the default shell for building
 MapGuide/FDO on Ubuntu, it should not be a requirement for running it.
 The recently introduced service control script is known to have bash-isms.
 The other scripts should also be checked for bash-isms. Such bash-isms
 should be replaced with standard equivalents.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2497>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
