[Mapguide-trac] [mapguide-trac] #2485: KML line thickness should be clamped to [some very small value > 0] if 0 line thickness defined
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 23 03:07:19 PDT 2014
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  3.0
  Component:  KML Service  |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 When a layer is exported to KML and the line/border thickness specified is
 0, such lines will not be shown on Google Earth as the actual thickness
 value is transferred as-is.
 This is not how MapGuide's image-based renderers deal with such a setting.
 These renderers will still draw said lines presumably with a [very small
 value > 0] for the line/border thickness.
 The KML renderer should follow the same behaviour as the image-based
 renderers, namely a 0 line thickness is specified in the Layer Definition,
 it should be replaced with a [very small value > 0] when the KML is
 written.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2485>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
