[Mapguide-trac] [mapguide-trac] #2491: DWF Toolkit 7.7 compilation failure on GCC 4.7 and above
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 29 06:06:13 PDT 2014
   Reporter:  jng           |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  3.0
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 Building trunk with freshly merged DWF Toolkit 7.7 on Ubuntu 14.04 64-bit
 produces compilation errors like this
 In file included from ../../../dwf/package/PropertySet.h:33:0,
                  from ../../../dwf/package/ContentElement.h:34,
                  from ../../../dwf/package/Class.h:36,
                  from ContentReader.cpp:25:
 ../../../dwfcore/Vector.h: In instantiation of 'bool
 DWFCore::DWFOrderedVector<T, Pr, Eq>::findFirst(const T&, size_t&) const
 [with T = DWFToolkit::DWFClass*; Pr =
 DWFCore::tDWFCompareLess<DWFToolkit::DWFClass*>; Eq =
 DWFCore::tDWFCompareEqual<DWFToolkit::DWFClass*>; size_t = long unsigned
 int]':
 ../../../dwf/package/Class.h:149:59:   required from here
 ../../../dwfcore/Vector.h:591:41: error: '_tEquals' was not declared in
 this scope, and no declarations were found by argument-dependent lookup at
 the point of instantiation [-fpermissive]
              if (_tEquals( oValue, *iter ))
 ../../../dwfcore/Vector.h:591:41: note: declarations in dependent base
 'DWFCore::DWFVector<DWFToolkit::DWFClass*,
 DWFCore::tDWFCompareLess<DWFToolkit::DWFClass*>,
 DWFCore::tDWFCompareEqual<DWFToolkit::DWFClass*> >' are not found by
 unqualified lookup
 ../../../dwfcore/Vector.h:591:41: note: use 'this->_tEquals' instead
 This is due to name lookup changes introduced in GCC 4.7
 The easiest solution would be to apply the `-fpermissive` compiler flag to
 convert these errors to warnings.
 The proper fix, would be to find and replace all instances of `_tEquals`
 with `this->_tEquals` as suggested by the compiler error message
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2491>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
