[Mapguide-trac] mapguide-trac Digest, Vol 102, Issue 2
Julián Felipe julianferes at gmail.com
Fri Jul 10 12:48:13 PDT 2015
Hello mapguide-trac,
I am developing an aplication about vehicle tracking and i don't hnow how
to draw a car image on a map's point .
Could you help me with it please.
Thank you
2015-07-09 14:00 GMT-05:00 <mapguide-trac-request at lists.osgeo.org>:
> Send mapguide-trac mailing list submissions to
>         mapguide-trac at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/mapguide-trac
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         mapguide-trac-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapguide-trac digest..."
> Today's Topics:
>    1. [mapguide-trac] #2563: Cannot make v3.0.0 untiled Map
>       Definitions (MapGuide Open Source)
>    2. [mapguide-trac] #2564: Feature Source XML doesn't properly
>       update when switching to unmanaged files in editor
>    3. Re: [mapguide-trac] #2564: Feature Source XML doesn't
>       properly update when switching to unmanaged files in editor
>    4. Re: [mapguide-trac] #2563: Cannot make v3.0.0 untiled Map
>    5. Re: [mapguide-trac] #2520: JenkinsCI/vagrant loose ends for
>       3.0 release cycle (MapGuide Open Source)
> Message: 1
> Date: Thu, 09 Jul 2015 11:50:15 -0000
> From: "MapGuide Open Source" <trac_mapguide at osgeo.org>
> Cc: mapguide-trac at lists.osgeo.org
> Subject: [Mapguide-trac] [mapguide-trac] #2563: Cannot make v3.0.0
>         untiled Map Definitions
> Message-ID: <041.f06fc8405424c4be7001fb3fef45416c at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
> #2563: Cannot make v3.0.0 untiled Map Definitions
>    Reporter:  jng      |      Owner:  jng
>        Type:  defect   |     Status:  new
>    Priority:  low      |  Milestone:  Maestro-6.0
>   Component:  Maestro  |    Version:
>    Severity:  trivial  |   Keywords:
> External ID:           |
>  Create a v3.0.0 Map Definition using the M4 release. Do not add any tiled
>  layers.
>  Saving fails with a content model error because the UI does not let you
>  specify an option that maps to the TileSetSource.None value.
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2563>
> MapGuide Open Source <http://mapguide.osgeo.org/>
> MapGuide Open Source Internals
> Message: 2
> Date: Thu, 09 Jul 2015 11:52:02 -0000
> Subject: [Mapguide-trac] [mapguide-trac] #2564: Feature Source XML
>         doesn't properly update when switching to unmanaged files in editor
> Message-ID: <041.d1dd302226221e0bac28ca2ccc7c3000 at osgeo.org>
> #2564: Feature Source XML doesn't properly update when switching to
> unmanaged
> files in editor
> External ID:           |
>  1. Create a new file-based Feature Source.
>  2. Browse to an aliased file.
>  3. Switch to unmanaged files.
>  Expect: The aliased file path to be in the Feature Source XML
>  Get: The aliased file path is not in the Feature Source XML. The file path
>  has to be manually edited for the changes to register in the XML.
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2564>
> Message: 3
> Date: Thu, 09 Jul 2015 12:02:01 -0000
> Subject: Re: [Mapguide-trac] [mapguide-trac] #2564: Feature Source XML
> Message-ID: <056.274876581343e0e10ad69cad2fda76ad at osgeo.org>
> unmanaged
> files in editor
>      Type:  defect   |       Status:  closed
> Component:  Maestro  |      Version:  2.5.0
>  Severity:  trivial  |   Resolution:  fixed
>  Keywords:           |  External ID:
> Changes (by jng):
>  * status:  new => closed
>  * version:   => 2.5.0
>  * resolution:   => fixed
> Comment:
>  Fixed r8699
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2564#comment:1>
> Message: 4
> Date: Thu, 09 Jul 2015 12:02:08 -0000
> Subject: Re: [Mapguide-trac] [mapguide-trac] #2563: Cannot make v3.0.0
> Message-ID: <056.9394f60b76cf20616ab77097c0ea5714 at osgeo.org>
> Changes (by jng):
>  * version:   => 2.5.0
> Comment:
>  Fixed r8699
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2563#comment:1>
> Message: 5
> Date: Thu, 09 Jul 2015 12:15:19 -0000
> Subject: Re: [Mapguide-trac] [mapguide-trac] #2520: JenkinsCI/vagrant
>         loose ends for 3.0 release cycle
> Message-ID: <056.81fabcc3d7ced20b718519fcfc2c7ad3 at osgeo.org>
> #2520: JenkinsCI/vagrant loose ends for 3.0 release cycle
>      Type:  task          |       Status:  new
>  Priority:  low           |    Milestone:  3.0
> Component:  Build System  |      Version:
> Description changed by jng:
> Old description:
> > * Update trunk Fusion app.version to 3.0.0 in build.xml. The version is
> > still 2.6.0 and is causing the buildtools package to not be copied to the
> > build artifact directory
> >  * Run the mgserver test suite with a file parameter and configure a
> > xUnit report task to report on the test output file
> >  * Also invoke the web tier test suite and log/report on its results.
> > This requires us to be able to programatically configure up a MapGuide
> > environment to run the tests in, so this item sort of depends on #2498
> New description:
>  * ~~Update trunk Fusion app.version to 3.0.0 in build.xml. The version is
>  build artifact directory~~
>   * Run the mgserver test suite with a file parameter and configure a xUnit
>   * Also invoke the web tier test suite and log/report on its results. This
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2520#comment:1>
> End of mapguide-trac Digest, Vol 102, Issue 2
Ing. Julian Felipe Feres Santander
Ingeniero De Software
URL: <http://lists.osgeo.org/pipermail/mapguide-trac/attachments/20150710/57f593ce/attachment.html>
More information about the mapguide-trac mailing list
