[Mapguide-trac] [mapguide-trac] #2544: Cannot edit composite symbolization as XML
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 5 05:28:55 PST 2015
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-6.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When attempting to edit the composite symbolization XML from the Composite
 Rule editor, saving fails because it attempts to validate the XML fragment
 against a schema that doesn't exist (we're editing a fragment of XML of a
 resource, so no such schema exists).
 As a result, in this case validation should only test for well-formedness.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2544>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
