[Mapguide-trac] [mapguide-trac] #2548: Selection not cleared server-side
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 9 01:33:23 PDT 2015
   Reporter:  gBecker   |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  General   |     Version:  2.6.0
   Severity:  critical  |    Keywords:
External_id:            |
 When using the AjaxViewer and trying to clear a selection then this
 selection is not cleared server-side.
 This is related to MGOS 2.6 and the preview release of MGOS 3.0.
 Steps to reproduce the Problem:
 1. Preview an existing MapDefinition with Maestro[[BR]]
 2. Select a feature[[BR]]
 3. Deselect the feature via toolbar or context menu[[BR]]
 4. Go to the "MapAgent Test Pages"[[BR]]
 5. Under "Rendering" service perform a "MAPIMAGE"-Request of the area
 where you formerly selected the feature.[[BR]]
 6. The selection is rendering with the map Image.[[BR]]
 I turned on the browsers network analysis and detected a "silent" error
 when you are deselecting features.
 The request that should probably clear the selection returns a 559 http-
 error:
 Request to mapagent.fcgi (POST):
 OPERATION=QUERYMAPFEATURES&VERSION=2.6.0&PERSIST=1&MAXFEATURES=-1&MAPNAME=da766655-a6f1-4981
 -916f-
 356b5e605b9f&SESSION=44ec47c2-c636-11e4-8000-a0d3c14fb893_en_MTI3LjAuMC4x0B600B5F0B5E&SEQ=0.5484117435160211&CLIENTAGENT=Ajax%20Viewer&LAYERATTRIBUTEFILTER=0&REQUESTDATA=8&FEATUREFILTER=
 return this error:
 Argument is null.
 - MgRenderingServiceHandler.ProcessOperation() line 83 file
 c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
 - MgOpQueryFeatures.Execute() line 125 file
 c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
 - MgServerRenderingService.QueryFeatures() line 853 file
 c:\working\build_area\mapguide\2.6.0\x64\mgdev\server\src\services\rendering\ServerRenderingService.cpp
 - MgServerRenderingService.RenderForSelection() line 1187 file
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2548>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
