[Mapguide-trac] [mapguide-trac] #2550: RFC 140 Errata
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 11 06:10:48 PDT 2015
   Reporter:  jng           |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  3.0
  Component:  Tile Service  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 According to the original RFC 140, I wrote the following about the XYZ
 tile provider
 The "XYZ" provider implements tile rendering and access using the XYZ
 tiling scheme. Coordinate System is always LL84 ...
 In further tests, this is proved to be incorrect. The actual Cooordinate
 System should actually always be WGS84.PseudoMercator
 Having a LL84 coordinate system for XYZ tile sets produces tiles with
 noticeable visual distortion, whereas tiles from XYZ tile sets with a
 WGS84.PseudoMercator coordinate system have more crisp visual fidelity.
 Attached is:
  * A visual comparison of two different XYZ tile sets in both LL84 and
 WGS84.PseudoMercator coordinate systems
  * A patch to set the correct coordinate system to WGS84.PseudoMercator
 instead of LL84
 From a client tooling perspective, tile sets should be working against the
 WGS84.PseudoMercator coordinate system instead of LL84 in terms of tile
 set extents being set and/or transformed.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2550>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
