[Mapguide-trac] [mapguide-trac] #2536: Maestro 5.1: Purge cached schema information don't work with MS-SQL-Server 2008 R2
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 16 15:17:46 PDT 2015
2008 R2
 Reporter:  BSellke   |         Owner:  jng
     Type:  defect    |        Status:  closed
 Priority:  high      |     Milestone:
Component:  Maestro   |       Version:  2.6.0
 Severity:  critical  |    Resolution:  wontfix
 Keywords:            |   External_id:
Changes (by BSellke):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 '''Solution - no! But a little workaround...'''
 I found a workaround by generating extensions and defining joins in the
 Data-Feature-Source in Maestro... It works pretty good, but i know nothing
 about performance against database internal views...
 Live long and in prosper
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2536#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
