[Mapguide-trac] [mapguide-trac] #2576: Schema report: Use explicit property list for query in showclass.php
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 19 05:57:41 PST 2015
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  new
   Priority:  low      |  Milestone:
  Component:  General  |    Version:  2.5.0
   Severity:  trivial  |   Keywords:
External ID:           |
 Reported here: http://osgeo-org.1560.x6.nabble.com/PostgreSQL-
 SelectFeatures-td5236983.html
 Currently showclass.php does the equivalent of "select * from table",
 which works fine most of the time, but in the case of the PostgreSQL FDO
 provider, causes errors if the mapped database table contains columns not
 supported or recognised by the FDO provider.
 The fix is to explicitly specify all the valid properties in the query
 before executing it.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2576>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
