[Mapguide-trac] [mapguide-trac] #2731: In Fusion Query Widget, fields with Spaces and Brackets give FDO Filter Errors
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 20 12:43:09 PDT 2016
Errors
   Reporter:  gluckett  |      Owner:
       Type:  defect    |     Status:  new
   Priority:  medium    |  Milestone:
  Component:  General   |    Version:  3.0.0
   Severity:  trivial   |   Keywords:  query
External ID:            |
 The Query widget fails in the underlying columns with unsupported
 characters such as brackets or spaces are found.
 Solution, add Quotes around field name in Filter.
 Main Size (m) > 50
 becomes
 "Main Size (m)" > 50
 Change \www\fusion\widgets\Query\classes\query.php
 Around line: 261
 from
  $propertyFilter = $this->args['PROPERTYNAME'];
 to
  $propertyFilter = '"' . $this->args['PROPERTYNAME'] . '"';
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2731>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
