[Mapguide-trac] [mapguide-trac] #2594: MapGuide 3.0: apache child abort on evaluating distance between MgPoints
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 27 08:47:16 PDT 2016
 Reporter:  gabrimonfa  |        Owner:  jng
     Type:  defect      |       Status:  closed
 Priority:  low         |    Milestone:
Component:  General     |      Version:  3.0.0
 Severity:  minor       |   Resolution:  fixed
 Keywords:              |  External ID:
Comment (by jng):
 In [changeset:"9011" 9011]:
 #!CommitTicketReference repository="" revision="9011"
 Merged revision(s) 9010 from trunk/MgDev:
 Fix #2594. Based on this GEOS ticket
 (https://trac.osgeo.org/geos/ticket/469), setting explicit -m32/-m64 flags
 in CFLAGS/CXXFLAGS/CPPFLAGS/FFLAGS/LDFLAGS before calling the geos
 configure script.
 Running "make check" without these changes reproduces the assertion error.
 Running "make check" with this change does not produce the assertion
 error.
Ticket URL: </ticket/2594#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
