[Mapguide-trac] [mapguide-trac] #2586: Parameterized vagrant provisioning script
MapGuide Open Source trac_mapguide at osgeo.org
Fri Mar 18 06:07:23 PDT 2016
   Reporter:  jng           |      Owner:  jng
       Type:  enhancement   |     Status:  new
   Priority:  low           |  Milestone:  3.1
  Component:  Build System  |    Version:  3.0.0
   Severity:  trivial       |   Keywords:
External ID:                |
 Currently our Linux builds are done through vagrant with distinct
 Vagrantfiles for:
  * CentOS 6.5 (32-bit)
  * CentOS 6.5 (64-bit)
  * Ubuntu 12.04 (32-bit)
  * Ubuntu 12.04 (64-bit)
 Inside each vagrantfile is lots of common and redundant shell script code
 that calls the underlying build scripts.
 To simplify these vagrantfiles, we should extract out this common shell
 script code into its own root provisioning shell script.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2586>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
