[Mapguide-trac] [mapguide-trac] #2585: The total entries is not correct with Oracle data source
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 12 08:17:21 PDT 2016
 Reporter:  zhanga     |        Owner:  jng
     Type:  defect     |       Status:  closed
 Priority:  low        |    Milestone:  3.1
Component:  Map Agent  |      Version:  3.0.0
 Severity:  trivial    |   Resolution:  fixed
 Keywords:             |  External ID:
Comment (by jng):
 In [changeset:"8960" 8960]:
 #!CommitTicketReference repository="" revision="8960"
 Merged revision(s) 8958-8959 from branches/3.0/MgDev:
 Merged revision(s) 8956 from trunk/MgDev:
 devguide: Fix malformed revision history table and add a section about
 mapguide-rest in supplemental_development.rst
 Merged revision(s) 8871, 8912, 8921, 8942 from sandbox/adsk/3.1n:
 Fix #2585: the total entries is not correct with Oracle data source.
 It is because the initial vale of total entries is -1. We should set it to
 0.
 Fix the issue that DateTime value cannot be displayed in selection panel.
 In some special FDO provider such as Autodesk RealDWG provider, the
 'Geometry' property is already in property mappings. In method
 MgHtmlController::WriteSelectedFeatureAttributes(), we will first add all
 mapping properties, then add geometry property. We need to check if
 'Geometry' is added to avoid adding it twice.
 Fix the defect that zoom raster image results in server crash.
 It is because if the displayed size of image is very small, the width or
 height may be 0. And we will use the width and height as the parameters of
 RESAMPLE. FDO Raster provider will crash in this case. I set width or
 height to 1 if its value is 0 to avoid the error.
Ticket URL: </ticket/2585#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
