[Mapguide-trac] [mapguide-trac] #2751: Error selecting more than 1000 features from SQLite FeatureSource
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 3 02:29:25 PDT 2016
 Reporter:  gBecker    |        Owner:  jng
     Type:  defect     |       Status:  new
 Priority:  high       |    Milestone:
Component:  Map Agent  |      Version:  3.0.0
 Severity:  major      |   Resolution:
 Keywords:             |  External ID:
Comment (by jng):
 Firstly, does this happen with MGOS 3.1 as well?
 Secondly, if the above answer is yes, I'm going to build and attach a
 patched MgMapGuideCommon.dll for MGOS 3.1 64-bit that incorporates the
 attached source code changes. Could you check if this dll fixes the issue
 in 3.1? If it does, I'll backport this fix for 3.0 and 2.6 as well.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2751#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
