[Mapguide-trac] [mapguide-trac] #2745: MgCooker: Tile count completely wrong when override coordinates specified
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 30 06:23:31 PDT 2016
 Reporter:  jng      |        Owner:  jng
     Type:  defect   |       Status:  new
 Priority:  low      |    Milestone:  Maestro-6.0
Component:  Maestro  |      Version:  2.5.0
 Severity:  trivial  |   Resolution:
 Keywords:           |  External ID:
Changes (by jng):
 * version:   => 2.5.0
Old description:
> 1. Select the Sheboygan tiled map
>  2. Start a tiling session. Observe that it has about 1.7 million tiles
> to process.
>  3. Stop the session and override its coordinates, cut down a few decimal
> places.
>  4. Re-run the tiling session. The session ends immediately, and most
> likely the calculated total is 0 or some very small number.
New description:
 1. Select the Sheboygan tile set
  2. Start a tiling session. Observe that it has about 127k tiles to
 process.
 places.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2745#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
