[Mapguide-trac] [mapguide-trac] #2768: Ubuntu install script changes for better usability with docker
MapGuide Open Source trac_mapguide at osgeo.org
Sat Apr 22 09:25:33 PDT 2017
 Reporter:  jng          |        Owner:  jng
     Type:  enhancement  |       Status:  closed
 Priority:  low          |    Milestone:
Component:  Installer    |      Version:
 Severity:  trivial      |   Resolution:  fixed
 Keywords:               |  External ID:
Comment (by jng):
 In [changeset:"9170" 9170]:
 #!CommitTicketReference repository="" revision="9170"
 Merged revision(s) 9163, 9166-9168 from trunk/Tools/Vagrant:
 Update clean.bat and Vagrantfiles in light of stupidity introduced in
 vagrant that demands the script file being referenced by the shell
 provisioner configuration physically exist, even if I just want to destroy
 the associated running VM!
 Fix bad provision script path for centos6/x86
 - Remove bash-isms from install script. This script now runs on vanilla
 POSIX sh. Fixes #2760
 - Add support for:
   --no-service-install: To prevent automatic installation of service
 scripts
   --no-mgserver-start: Do not auto-start mgserver
   --no-tomcat-start: Do not auto-start tomcat
   --no-httpd-start: Do not auto-start httpd
 All these new flags only apply if the --headless flag is specified. Fixes
 #2768
 Merged revision(s) 8967, 8972-8973 from branches/3.1/vagrant:
 Fix release label not being properly stamped onto ubuntu install script as
 it was looking for a default label that doesn't exist.
 Update ubuntu install script:
  - Add extra pre-requisite packages that were discovered to be required
 when testing on a clean barebones Ubuntu server installation.
 Remove libc6 requirement from mginstallubuntu.sh. This package will always
 be present.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2768#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
