[Mapguide-trac] [mapguide-trac] #2780: MentorUserDictionaryPath should also be available in webconfig.ini
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 3 10:16:46 PDT 2018
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  assigned
   Priority:  low      |  Milestone:  3.3
  Component:  Web API  |    Version:  3.1.0
   Severity:  trivial  |   Keywords:
External ID:           |
 Currently, the MentorUserDictionaryPath property is only defined in
 serverconfig.ini, meaning the mgserver process is aware of user
 dictionaries.
 However, webconfig.ini does not define such a property, nor does
 {{{MgInitializeWebTier}}} look for this property in webconfig.ini
 What this means is that outside of using the default
 {{{MENTOR_USER_DICTIONARY_PATH}}}, the MapGuide Web Tier is not aware of
 any user dictionaries the MapGuide Server Tier would know about because
 there's no way to point both server and web tier to the same directory for
 user dictionaries.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2780>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
