[Mapguide-trac] [mapguide-trac] #2805: Bitonal Images Colour Override Not Respected in Viewer
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 3 05:01:33 PDT 2019
 Reporter:  crispinatime  |        Owner:  (none)
     Type:  defect        |       Status:  new
 Priority:  medium        |    Milestone:  4.0
Component:  Server        |      Version:  3.1.0
 Severity:  major         |   Resolution:
 Keywords:                |  External ID:
Comment (by jng):
 Are you sure? I just made a throwaway map with NaturalEarth raster with a
 text watermark (the NE attribution text) and it appears just fine (see
 attached text_watermark.png)
 Regarding the underlying issue at hand. I wonder if the WMS FDO provider
 supports bitonal images. If you served your raster image behind another
 WMS server (for the sake of argument, something *not* MapGuide) and then
 try to setup a WMS raster image layer in MapGuide with the desired bitonal
 color settings, do these color settings apply in this case?
 If the WMS provider works in this case, then it may assist in getting
 bitonal image support into the GDAL FDO provider because I'm pretty sure
 the WMS FDO provider also uses GDAL as well.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2805#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
