[Mapguide-trac] [mapguide-trac] #2815: CMake: mod_mgmapagent.so is built with missing RPATH
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 24 04:26:36 PDT 2020
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  low           |  Milestone:  4.0
  Component:  Build System  |    Version:
   Severity:  trivial       |   Keywords:
External ID:                |
 Currently, the CMake build of `mod_mgmapagent.so` is set up with an RPATH
 of `$ORIGIN/../../lib64`
 This is insufficient as the load context is from
 `$INSTALL/webserverextensions/apache2/modules` which means it will try to
 load depdendent libraries from `$INSTALL/webserverextensions/lib64`, which
 does not contain
 `libMgFoundation`/`libMgGeometry`/`libMgPlatformBase`/`libMgMapGuideCommon`/etc
 as that is actually up one level.
 In summary, we need the RPATH to be the following:
  * `$ORIGIN/../../lib64`
  * `$ORIGIN/../../../lib64`
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2815>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
