[Mapguide-trac] [mapguide-trac] #2832: Rounding issue in raw geojson
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 23 22:29:03 PST 2020
   Reporter:  gBecker          |      Owner:  (none)
       Type:  defect           |     Status:  new
   Priority:  medium           |  Milestone:  4.0
  Component:  Feature Service  |    Version:
   Severity:  minor            |   Keywords:
External ID:                   |
 There is a rounding issue with the geojson format MapGuide 4 is
 producing. When you have a number like for example 476706.999999999 in
 your coordinates (request with a precision set to 7) then this leads to a
 number with a decimal point at the end
 476707.
 instead of just
 476706
 You can see the original data I requested with SELECTFEATURES in the
 screenshot from developer tools. Although it is shown in web developer
 console there is an error message when requesting in the browser:
 SyntaxError: JSON.parse: unterminated fractional number at line 1 column
 317 of the JSON data
 So, OpenLayers doesn't show this geojson. Of course, I can choose a higher
 precision to solve the issue with this specific coordinate but I have
 plenty of other coordinates that have the same problem even with a higher
 precision.
 By the way, with MapGuide Rest the geojson output is correct.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2832>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
