[Mapguide-trac] [mapguide-trac] #2846: CREATERUNTIMEMAP does not xml-encode layer names (was: CREATERUNTIMEMAP is skipping some layers in Map Definition)
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 20 06:23:39 PDT 2022
 Reporter:  jng      |        Owner:  jng
     Type:  defect   |       Status:  assigned
 Priority:  low      |    Milestone:  4.0
Component:  General  |      Version:  3.1.0
 Severity:  trivial  |   Resolution:
 Keywords:           |  External ID:
Changes (by jng):
 * summary:  CREATERUNTIMEMAP is skipping some layers in Map Definition =>
Old description:
> From https://github.com/jumpinjackie/mapguide-react-layout/issues/1401
> A CREATERUNTIMEMAP operation against that particular map definition is
> skipping a whole bunch of layers for some reason.
New description:
 UPDATE: The reason is because a few layer names have ampersand (`&`)
 characters that result in an invalid CREATERUNTIMEMAP XML response, which
 derails the JSON conversion at the layer which has an ampersand in its
 layer name
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2846#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
