[Mapguide-trac] [mapguide-trac] #2845: FAILED Server Tests - Int32ToLocaleSpecificString ( Util.cpp) versus MgIsLegalUTF8 (ConvertUTF.c)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 4 22:55:37 PDT 2022
 Reporter:  pcardinal                            |        Owner:  jng
     Type:  defect                               |       Status:  closed
 Priority:  medium                               |    Milestone:  4.0
Component:  Mapping Service                      |      Version:
 Severity:  minor                                |   Resolution:  fixed
 Keywords:  Unbreakable blank space utf-8        |  External ID:
  server test MgIsLegalUTF8                      |
Changes (by jng):
 * owner:  (none) => jng
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"10005" 10005]:
 {{{#!CommitTicketReference repository="" revision="10005"
 Make MgIsLegalUTF8 work under French Localization. Patch by Pierre
 Cardinal.
 Fixes #2845
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2845#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
