[Mapguide-trac] [mapguide-trac] #2874: Error on MgMappingUtil.StylizeLayers
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 19 02:34:01 PDT 2023
 Reporter:  dfanetti  |        Owner:  (none)
     Type:  defect    |       Status:  new
 Priority:  low       |    Milestone:
Component:  General   |      Version:
 Severity:  trivial   |   Resolution:
 Keywords:            |  External ID:
Comment (by jng):
 Wow! How did I missing DWF Toolkit in my sqlite search? I think you're on
 to something here.
 We had issues in the past in the SDF and SQLite FDO providers, where
 somehow the "wires got crossed" and these providers were calling
 `sqlite3_*` functions in the DWF Toolkit core library instead of their own
 private versions of SQLite in their own provider `.so` files. We fixed
 these issues by making these providers compile on linux with `-BSymbolic`
 to force these provider `.so` files to look within themselves when calling
 `sqlite3_*` functions.
 But before I look at possible remedies, I'd like to see this issue be more
 reproducible.
 Instead of a postgis database, could you perhaps `ogr2ogr` a subset of the
 data from postgis to some flat file format and if you setup a OGR feature
 source to this flat file instead, does the problem still occur?
 And if it is reproducible with a flat file via an OGR feature source,
 could I then get a copy of this flat file?
 Thanks.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2874#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
