[Mapguide-trac] [mapguide-trac] #2877: Drop doxygen and use per-language API documentation tools
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 10 12:46:10 PST 2023
 Reporter:  jng            |        Owner:  jng
     Type:  task           |       Status:  assigned
 Priority:  low            |    Milestone:  4.0
Component:  Documentation  |      Version:
 Severity:  trivial        |   Resolution:
 Keywords:                 |  External ID:
Description changed by jng:
Old description:
> Doxygen is currently our API doc generation tool, which is not suitable
> for our API documentation needs due to its C++-centric nature and our
> downstream API consumers being the 3 managed language bindings to this
> C++ API.
> Instead, we should generate API documentation for each language target in
> their preferred documentation tool of choice and implement a static
> landing page that links to all 3 generated API docs.
> For this, we will use the following tools for each respective language
> target:
>  * PHP: [https://github.com/code-lts/doctum doctum]
>  * .net: [https://dotnet.github.io/docfx/ docfx]
>  * Java: The built-in `javadoc` that comes with the JDK
> Thanks to the support in IMake for transferring API doc fragments to the
> .net and Java proxy classes implemented a long time ago, most of the hard
> work is already done for us. The only gap is PHP, where we will require
> IMake to generate stub PHP proxy classes (with transferred API doc
> fragments) for the purpose of running doctum against it.
> With this in place, we can drop doxygen and all of its associated files
> from our source tree.
> Task breakdown:
>  * [x] Add helper script to acquire required documentation tools
>  * [x] Add docfx project
>  * [ ] Update IMake to support generation of PHP stub classes with
> transferred API documentation
>  * [x] Add top-level doc build script to run docfx, javadoc and doctum
> against their respective proxy class source files
>  * [~] Convert all doxygen conceptual topics over to markdown .md files
>  * [x] Determine a suitable static site generator that supports code
> syntax highlighting in Java, C# and PHP (we chose docfx)
>  * [x] Add a static landing site that links to the docfx, javadoc and
> doctum generated API docs
>  * [ ] Java: Document unique features of the Java binding (mine MapGuide
> RFC 129 and 185 for content)
>  * [ ] .net: Document unique features of the .net binding (mine MapGuide
> RFC 185 for content)
>  * [ ] PHP: Document the fact that `constants.php` no longer exists and
> the constant defns are now baked into the PHP extension itself
>  * [~] Add conceptual topics to the landing site
>  * [ ] Package zip of the landing site with the 3 language-specific API
> docs
New description:
 downstream API consumers being the 3 managed language bindings to this C++
 API.
 target:
 Task breakdown:
  * [x] .net: Document unique features of the .net binding (mine MapGuide
 docs
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2877#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
