[mapguide-users] 2003 Server Mapguide Install Still have the same problem
Bruce Dechant bruce.dechant at autodesk.com
Tue Apr 4 16:47:07 EDT 2006
Philip,
We have some machines setup with Windows 2003 for both development and
testing and we are not seeing this problem. I had a look and the only
difference is that you have mapped IIS to D:\Inetpub instead of the
default location. This might be the cause of the problem and is
something we will need to investigate.
Bruce
-----Original Message-----
From: Philip Martins [mailto:philm at plan-tech.com]
Sent: Tuesday, April 04, 2006 11:09 AM
Subject: [mapguide-users] 2003 Server Mapguide Install Still have the
same problem
I have a 2003 server machine with IIS 6.0 mapped to the d:\Inetpub
directory, .net framework is also installed .  When I try to install the
MgWebServerExtensionsSetup.exe with the IIS configuration option, I get
a
message stating "The required version of IIS was not detected on your
machine" and the install stops.  Any ideas?
Thank you
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.375 / Virus Database: 268.1.0/269 - Release Date: 2/24/2006
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
