[mapguide-users] Windows Operating System
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Apr 4 21:44:50 EDT 2006
True - .NET will be a problem with Apache.
I was also wrong about the default of two connections (I got this confused with the HTTP 1.1 spec which specifies a limit of two simultaneous connections to the same server).  For IIS on XP Pro the default limit is 10 connections, and if you apply the workaround you can increase this to 40.
Walt
	-----Original Message-----
	From: Andy Morsell [mailto:amorsell at spatialgis.com]
	Sent: Tue 4/4/2006 8:18 PM
	Cc:
	Subject: RE: [mapguide-users] Windows Operating System
	The only problem with this is if you want to use the .NET web extensions.  The available Apache .NET module does not fully support .NET 2.0 and the MapGuide API.  You can partially get around the IIS simultaneous connection issue by editing the Windows metabase.  I have done this and have not had any issues developing MGOS applications on XP Pro (but our production server is a server OS).  Details on this are in a document I wrote for MapServer Enterprise installs.  Much of this document does not apply anymore with the release of MGOS 1.0, but this particular section, the very last one in the document, still does apply.  It can be downloaded from http://www.spatialgis.com/mse_install_tips.pdf
	Andy Morsell, P.E.
	Spatial Integrators, Inc.
	http://www.SpatialGIS.com
  _____
	From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
	Sent: Tuesday, April 04, 2006 2:27 PM
	Also if you do use XP, then Apache is the preferred Web server.  Apache supports an unlimited number of simultaneous connections, while IIS on XP only supports two.  If you want to use IIS then you should install MapGuide on a server OS.
	Walt
  _____
	Sent: Tuesday, April 04, 2006 5:20 PM
	Molly,
	MapGuide is a server application and should be run on a “Server Class” operating system, ie: Windows 2000 and Windows 2003.
	However, it does work on Windows XP, but is not “Officially” supported. For demo purposes in house we have setup MapGuide server and Studio on a Windows XP machine, but again this is not officially supported. For any real applications you should be using a “Server Class” operating system.
	Bruce
  _____
	From: Molly Thompson [mailto:molly_t42 at yahoo.com]
	Sent: Tuesday, April 04, 2006 3:05 PM
	Subject: [mapguide-users] Windows Operating System
	Hello All,
	Does Mapguide Server work  on windows XP Professional?
	As mentioned in the requirements, it works only on Windows NT 2003 and Windows 2000.
	But it is not specified in the Installation guide  (https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf) that what operating system should be used?
	Regards,
	Molly Thompson
  _____
	Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min. <http://us.rd.yahoo.com/mail_us/taglines/postman7/*http:/us.rd.yahoo.com/evt=39666/*http:/beta.messenger.yahoo.com>
  _____
	How low will we go? Check out Yahoo! Messenger’s low <http://us.rd.yahoo.com/mail_us/taglines/postman7/*http:/us.rd.yahoo.com/evt=39666/*http:/beta.messenger.yahoo.com> PC-to-Phone call rates. <http://us.rd.yahoo.com/mail_us/taglines/postman8/*http:/us.rd.yahoo.com/evt=39663/*http:/voice.yahoo.com>
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060404/e9a4619b/attachment.bin
More information about the Mapguide-users mailing list
