AJAX viewer zoom slider
Jason Birch Jason.Birch at nanaimo.ca
Fri Apr 7 11:12:23 EDT 2006
Is it just me, or does having a zoom slider where the top 1/3 is
dedicated to scales greater than 1:1 not make any sense?  This appears
to be the case in the maps that I have made that don't have base layers.
The slider function itself appears to use a pretty good algorithm to
zoom progressively, but I think that it might be more useful if:
 - It was integer-based, and/or
 - It was possible to specify min/max scales for a given map
I put in a defect report for this a while back:
https://mapguide.osgeo.org/servlets/Scarab?id=MG146
In the meantime, can anyone suggest a workaround?
Thanks,
Jason
More information about the Mapguide-users mailing list
