[mapguide-users] question
Jason Birch Jason.Birch at nanaimo.ca
Mon Apr 10 13:02:58 EDT 2006
Not yet.
Bob has indicated in earlier email (look for "Commercial vs. Open Source Functionality") that:
- Studio is a commercial product. There is an open source web-based
variation in the works that we plan to have available later this spring.
It will not be as functional as the commercial version, but it will be a
full open source project.
- The initial Studio Lite will be a subset, with support for creating SDF and SHP data sources, layers, and maps. It's all just an HTML based web application though so pretty easy for someone in the open source domain to extend.
Nothing to stop you from doing this yourself in the meantime.  The API is fairly straightforward:
https://mapguide.osgeo.org/nonav/docs/webapi/de/d2f/group___working_with_resources_g613e2512f7e7c06b772e57ffd132aedd.html
Also, see this email for details on how to add resources through the mapagent/index.html file:
https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321
Note that there will be no support for the proprietary DWG format in anything but Studio.  Good reason not to use DWGs (Map 3D 2007 will support the SDF FDO provider).
Jason
From: "Antonio Lucas Rodríguez (sr&tec)" [mailto:alucas at srtec.com]
Sent: Monday, April 10, 2006 09:48
Subject: [mapguide-users] question
Hi all,
I've a question. The MakePackage tool works fine, but there are any php script that can help me to create packages from spatial data files (SDF, SHP, DWG ...)? It seems that for people like me with non-english version of windows, Autodesk Studio fails loading resources.
Thanks in advance.
Antonio Lucas
Software Engineer
alucas at srtec.com	 www.srtec.com
 963·959·513
	Fax 963·731·756
 	 SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
More information about the Mapguide-users mailing list
