[mapguide-users] RE: MapGuide OS with Google Earth
Traian Stanev traian.stanev at autodesk.com
Tue Apr 11 09:58:24 EDT 2006
You're right. I only get 100 features when I read via a php script, which happens to be the default batch size when sending data from the server process to the web server. Studio's preview data is prepared on the server itself so it talks more or less directly to FDO and gets all the features correctly. I will investigate the cause of this and get back to you.
Traian
  _____
Sent: Tuesday, April 11, 2006 9:09 AM
Subject: RE: [mapguide-users] RE: MapGuide OS with Google Earth
I'm converting to SDF, but I also tried not to, but that had the same results...
Willem
  _____
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: dinsdag 11 april 2006 15:05
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] RE: MapGuide OS with Google Earth
Did you load the file as SHP or convert to SDF? I'm asking so that I can give it a shot myself with your file.
Traian
  _____
Sent: Tuesday, April 11, 2006 9:01 AM
Cc: grosser at kom21.de
Well,
If I load the shape in Studio I see the adamStudio.jpg picture...
When opening KML file in Google I only see adamGoogle.jpg...
Thanks,
Willem
  _____
Van: Thomas Grosser [mailto:grosser at kom21.de]
Verzonden: dinsdag 11 april 2006 14:52
Onderwerp: AW: [mapguide-users] RE: MapGuide OS with Google Earth
Dear Willem,
may be i didn´t understand the "real" problem, but in my enviroment everything seam to be ok. Can you describe me in detail whats your problem ?
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
  _____
Von: Willem Schwarte [mailto:willem at giskit.nl]
Gesendet: Dienstag, 11. April 2006 13:50
An: users at mapguide.osgeo.org
Betreff: RE: [mapguide-users] RE: MapGuide OS with Google Earth
Maybe someone can clarify this for me, loading this shape in Studio results in a lot of lines. When using this to export to KML it returns only a very small part.
Can't seem to figure out how the readNext() works, and why it stops early???
Hope somebody can check this for me, would be nice for a demonstration tomorrow.
Thanks...
http://www.gisnet.nl/adam.zip
Willem
  _____
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: dinsdag 11 april 2006 11:51
Nevermind.... Transforming the coordinates to lat long worked!
Willem
  _____
Verzonden: dinsdag 11 april 2006 11:17
Ok, that worked, now I'm getting coordinates...  but in Google Earth the map is zoomed to completely the wrong place.
Could this be that our coordinate system differs from what Earth is expecting?
I'm getting this from my resources:
Boundary Line#myBoundaryLine0clampedToGround157086.938,403382.689,0 157078.527,403376.459,0 157074.187,403374.389,0 157070.947,403375.979,0 157068.266,403381.019,0 157069.616,403384.109,0 157080.227,403390.199,0 157082.778,403390.529,0 157084.707,403389.319,0 157087.568,403385.819,0 157086.938,403382.689,0
Our coordinate system is Arbritrary X-Y Meters... the Sheybogan is WGS84.
Willem
  _____
Van: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Verzonden: maandag 10 april 2006 18:37
Aan: Willem Schwarte
CC: users at mapguide.osgeo.org
Onderwerp: [mapguide-users] RE: MapGuide OS with Google Earth
Something that I've recently figured out is that it's a lot easier to debug Mg errors if you wrap your code in Try/Catch.  Have a look at some of the code in the mapadmin area, or in the package command line utilities I posted about yesterday.
I wonder if the geometry column for your data source is the same as the sample data (SHPGEOM).
You can see what this is supposed to be by looking at a layer based on that feature source in Studio, under "Feature Data Setup".  You can also get this information by going into the mapagent/index.html file, clicking on Feature Service API in the upper left, then clicking on Describe Feature item, and finally fill in the FeatureSource ID
Library://Bolsward/Data/Data/totaal_tvg32010101_v.FeatureSource
The sample data definition looks like this:
  <xs:complexType name="HydrographicPolygonsType" abstract="false" fdo:geometryName="SHPGEOM">
The fdo:geometryName attribute is what you want here.
A better solution would be to let the code extract the geometry column... hmm... bit of research later:
You could replace this line:
  $byteReader = $featureReader->GetGeometry('SHPGEOM');
With this:
  $byteReader = $featureReader->GetGeometry($featureReader->GetClassDefinition()->GetDefaultGeometryPropertyName());
Note that this isn't very efficient; it checks the default geometry property on each feature object.  It would be better to do this outside of the loop, or at the top of the loop in a section that's only executed once.
Jason
  _____
Sent: Monday, April 10, 2006 07:38
To: Jason Birch
Cc: users at mapguide.osgeo.org
Subject: RE: MapGuide OS with Google Earth
I have tried your sample for Google Earth, and it work fine with the sheybogan sample data.
If I paste this in my internet Explorer http://localhost/sites/google_earth\water.php <http://localhost/sites/google_earth/water.php>  I will get a bunch of coordinates.
But when I try to use my own data I get an error:
PHP Fatal error: Uncaught exception 'mgobjectnotfoundexception' in Unknown on line 0
In the water.php file I change this line like so:
$featureReader = $featureService->SelectFeatures(new MgResourceIdentifier("Library://Bolsward/Data/Data/totaal_tvg32010101_v.FeatureSource"), "totaal_tvg32010101_v", null);
As you can see in XML below, this does exist.  Do you might know why I don't get anything ?
Thanks,
Willem
<ResourceId>Library://Bolsward/Data/Data/totaal_tvg32010101_v.FeatureSource</ResourceId>
  <Depth>4</Depth>
  <Owner>Administrator</Owner>
  <CreatedDate>2006-04-07T08:32:36Z</CreatedDate>
  <ModifiedDate>2006-04-07T08:32:36Z</ModifiedDate>
- <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2F&TYPE=&DEPTH=-1##>  <ResourceDocumentHeader xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
- <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2F&TYPE=&DEPTH=-1##>  <General>
  <IconName>FeatureSourceSdf</IconName>
  </General>
- <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2F&TYPE=&DEPTH=-1##>  <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
  <Inherited>true</Inherited>
- <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2F&TYPE=&DEPTH=-1##>  <Groups>
- <http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library%3A%2F%2F&TYPE=&DEPTH=-1##>  <Group>
  <Name>Everyone</Name>
  <Permissions>r,w</Permissions>
  </Group>
  </Groups>
  </Security>
  </ResourceDocumentHeader>
  </ResourceDocument>
  _____
Verzonden: dinsdag 14 maart 2006 8:19
Onderwerp: MapGuide OS with Google Earth
I've uploaded a pretty basic example of using MapGuide OS to serve KML to Google Earth, based on an example that Bob Bray provided with the first preview:
http://www.jasonbirch.com/files/google_earth.zip
This is totally unsupported, but in my experience it works with the Sheboygan data set.  On a standard Windows/Apache/Php install you should just have to follow the instructions in the readme.txt file.
I had a better example that worked to return data for the current bounding box (you can see it in action at http://earth.nanaimo.ca/ ) but I was unable to get this working with the sample data, so either something has changed with 1.0 or the sample data is different somehow than what I'm serving.  I didn't get any error messages, but seeing all of the exception codes in the API, I guess I should be trapping for these somehow.  Not enough time to research now though.
My to-do list:
- clean up the code, make it more modular, and possibly use TJ's KMLDocument class for generating the KML:
http://kml.tjworld.net/downloads.php
- figure out how to read the default scale ranges and symbology from MapGuide, and return a semblance of those instead of having to custom code each layer.
- dynamically rewrite the bounding box, so that it shifts to the foreground when the view is tilted, allowing delivery of data without killing the server with a huge extent
- deliver GroundOverlay images as an option for small-scale mapping where serving vectors is inappropriate
Of course Autodesk could just step in any time now and provide a template for default delivery of KML :)
Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060411/218bb2ba/attachment.html
More information about the Mapguide-users mailing list
