Specify Shapefile Geometry
Rod Buchinski rbuchinski at sylvanlake.ca
Tue Apr 11 15:21:21 EDT 2006
Good Day,
For some reason mapguide is unable to understand the geometry of my
shapefile. The shapefile is a polygon with the geometry information
contained in the 'Shape' field. However when I use the 'Shape' field in
the following code I get an error which states: "The specified object
was not found - GetItem line 115".
Here is the code:
                                                    $byteReader =
$featureReader->GetGeometry('Shape');
                                                    $geometry =
$geometryReaderWriter->Read($byteReader);
                                                    $point =
$geometry->GetCentroid();
                                                    $x =
$point->GetCoordinate()->GetX();
                                                    $y =
$point->GetCoordinate()->GetY();
so what I think should happen here is the GetGeometry function should
look at the 'Shape' field, identify that the shapefile is a polygon,
then get the xy coordinates of the centroid of the polygon which is then
sent to another function which can then  zoom to those coordinates. But
I keep getting the error that I mentioned. Could anyone point me in the
right direction?
Rod
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060411/f2145a3e/attachment.html
More information about the Mapguide-users mailing list
