[mapguide-users] ODBC problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Apr 12 16:29:05 EDT 2006
If you get a chance, can you outline the steps that got you to that
point? Either I'm missing something painfully obvious, or else it's just
not working for me.
Andrew
Andy Morsell wrote:
> I have been able to connect to a variety of Access databases via ODBC
> without any of the issues you describe below.  I have then been able
> to create a join with another feature source (an SDF file) and create
> a layer from that.  But, my geometry does not show up in the preview
> when I create a layer from it, so I'm not sure what's going on there.
> More testing for another day when I can afford to get away from the
> work that pays the bills.........
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Wednesday, April 12, 2006 12:46 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] ODBC problem...
> Has anyone managed to get around this issue? Is there anyone who has
> successfully gotten an Access database to work using the ODBC provider
> (or any other way, for that matter)?
> Andrew
> Andrew DeMerchant wrote:
>> Yes it's an Access 2000 database.
>> Andrew
>> Robert Fortin wrote:
>>> Andrew,
>>> Was it done against an Access db?
>>> RF
>>> *Sent:* Tuesday, April 11, 2006 12:57 PM
>>> I got this:
>>>     An exception occurred in FDO component. RDBMS: No current open
>>>     database.
>>> database. Exception occurred in method MgFdoConnectionManager.Open
>>> at line 912 in file
>>> c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
>>> Andrew
>>> Joel Carranza wrote:
>>>> Well, the first time I tried this, I got a short reply of "False"
>>>> and then the MapGuide service crashed. Nothing reported in any of
>>>> the error logs. Restarted and ran again.
>>>> I got the following:
>>>>     An exception occurred in FDO component. Bad parameter to method.
>>>> Exception occurred in method MgFdoConnectionManager.Open at line
>>>> 912 in file
>>>> Any ideas?
>>>> --Joel
>>>> *From:* Tom Fukushima [mailto:tom.fukushima at autodesk.com]
>>>> *Sent:* Tuesday, April 11, 2006 9:31 AM
>>>> *Subject:* RE: [mapguide-users] ODBC problem...
>>>> Hi Andrew,
>>>> The diagnostic information that shows up in the test connection
>>>> information area is not very useful (this problem has been fixed
>>>> recently but is not in Studio 16802).  Please try the following:
>>>> 1) Open your browser to the HTML index of MapGuide web tier. It has
>>>> the form: http://<servername>/mapguide/mapagent/index.html
>>>> <http://%3Cservername%3E/mapguide/mapagent/index.html>. (Message
>>>> https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321
>>>> <https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321> also
>>>> has information on how to get to these pages.)
>>>> 2) Click on the Feature Service API link in the top left frame.
>>>> 3) Click on the TestConnection link in the bottom left frame.
>>>> 4) In the Resource ID field, type in the name of the ODBC feature
>>>> source that you created.  This should have the form
>>>> Library://<path>/<name>.FeatureSource.
>>>> 5) Press Submit
>>>> The resultant web page should give information on why the
>>>> connection is not working.
>>>> Hope this helps,
>>>> Tom
>>>> *From:* Joel Carranza [mailto:jec at gatekeeper.com]
>>>> *Sent:* Tuesday, April 11, 2006 10:29 AM
>>>> I don't think that the project is just with Jet connections. I have
>>>> been unable to get any kind of ODBC (access, Oracle ODBC)
>>>> connection to work, resulting in an identical error. I get similar
>>>> results using either the Data Source Name or Connection String options
>>>> Joel Carranza
>>>> Gatekeeper Systems
>>>>> I've just installed the latest Mapguide, Mapserver, and Studio as
>>>>> well as the ODBC and Raster providers. Everything working fine,
>>>>> except the ODBC. I've got a Jet connection set up on my computer,
>>>>> and the provider does find it...I select the data source name,
>>>>> save the connection, and then try "Test Connection" and get some
>>>>> errors:
>>>>> System.Net.WebException: The remote server returned an error:
>>>>> (559) MgFdoException.
>>>>>    at
>>>>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetRequestToString(Operation
>>>>> operation)
>>>>>    at
>>>>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
>>>>> resourceId, String provider, String connectionString)
>>>>>    at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>>>>>    at
>>>>> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
>>>>> sender, EventArgs e)
>>>>> Am I missing something here, or does it just not yet work with Jet
>>>>> databases? My data source is totally fine, as it works with other
>>>>> web apps that I have made.
>>>>> Andrew
>>>>> ps - Great work on the Raster provider!
>>>>> 	*Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.506-453-1025
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>> 	*Andrew DeMerchant*
>>> ph.506-453-1025
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>> 	*Andrew DeMerchant*
>> ph.506-453-1025
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> 	*Andrew DeMerchant*
> ph.506-453-1025
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
More information about the Mapguide-users mailing list
