performance problems
Marko Podgoršek Marko.Podgorsek at kaliopa.si
Thu Apr 13 03:50:46 EDT 2006
Hi!
I installed mapguide server and and mapguide web server extensions on Win2000 SP4 (IIS 5.0).
When I tested the dotnetviewersample with Sheboygan.mgp the performance of the server is very slow.
The ajax viewer shows the map, the dwf viewer doesn't even load the map.
Still, the ajax viewer is very slow, it takes about 1 minute or more to load the map at http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
The dwf viewer stops at cca. 90% if you look at the progress bar at the top left corner.
I used the IIS Configuration type on install.
What's wrong?
Marko Podgoršek
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060413/9d4fc6de/attachment.html
More information about the Mapguide-users mailing list
