[mapguide-users] Raster issues
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Apr 13 10:46:46 EDT 2006
Works fine for me with MrSID files. Haven't treid any other types yet.
Andrew
Berdel, Brian wrote:
> I am able to load raster files into studio, but when I try to preview
> the map it gives repeated errors and the only way out of it is to end
> the studio.exe process... anyone else experiencing this?
> *From:* Marko Podgoršek [mailto:Marko.Podgorsek at kaliopa.si]
> *Sent:* Thursday, April 13, 2006 3:51 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] performance problems
> Hi!
> I installed mapguide server and and mapguide web server extensions on
> Win2000 SP4 (IIS 5.0).
> When I tested the dotnetviewersample with Sheboygan.mgp the
> performance of the server is very slow.
> The ajax viewer shows the map, the dwf viewer doesn't even load the map.
> Still, the ajax viewer is very slow, it takes about 1 minute or
> more to load the map at
> http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
> The dwf viewer stops at cca. 90% if you look at the progress bar at
> the top left corner.
> I used the IIS Configuration type on install.
> What's wrong?
> Marko Podgoršek
	*Andrew DeMerchant*
*Computer Technologist*
ph.506-453-1025
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
