problem with setresource
Paul Spencer pspencer at dmsolutions.ca
Thu Apr 13 13:59:34 EDT 2006
I'm not sure what to do with this.  I am calling the MapAgent
SETRESOURCE operation through a proxy script (PHP).  The content of
the resource is passed as a string to the proxy script which then
adds the appropriate multipart form information to get MapGuide to
accept the resource content.  This works (once I figured out that it
requires a file name).  However, if the proxy script is on a machine
with Apache 1.3, the XML content gets quotes in the xml escaped so
you end up with tags like
<tag attr=\"test\"/>
which causes MapGuide server to fail to load the content.
The same proxy running on Apache 2.0 works without problem (because
it doesn't escape the quotes).
Is this a problem with MapGuide server (i.e. should it be unescaping
quotes)?  Is this a bug in some Apache versions?  Should I not worry
about it and make it a requirement for my app to run under Apache 2.x?
Cheers
Paul
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
More information about the Mapguide-users mailing list
