[mapguide-users] 1.0 Stability Problems
Robert Bray robert.bray at autodesk.com
Sat Apr 15 02:07:20 EDT 2006
Andy,
We are currently tracking a regression bug that has these exact
symptoms. Once we have tracked it down and are sure it's fixed, we'll
try to post a patch of some sort. At this point I don't think it's worth
you spending cycles on it, but we'll let you know if we do need some
help.
Thanks,
Bob
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, April 14, 2006 5:50 PM
Subject: [mapguide-users] 1.0 Stability Problems
I have been having problems with MapGuide Open Source Server locking up
and ceasing to respond on a Windows 2000 Server that is using the .NET
web extensions.  This has been happening about once a day.  When this
does occur, the MapGuide service cannot be stopped and I have to use the
kill command to kill the process and then restart the service.  The
windows event logs aren't very helpful since most of the events are
after it has locked up and are session errors (since the server is not
responding).  The same with the MapGuide error and access logs - there
is nothing obvious.  Are there any general, known stability issues at
the moment or should I try to track this deeper?  Any ideas where I can
get some clues about what is causing the problem?  This is the same
server that has been running all the prior releases and RC1 was the most
stable, with no restarts needed.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060414/58d287b0/attachment.html
More information about the Mapguide-users mailing list
