1.0 Stability Problems
Andy Morsell amorsell at spatialgis.com
Tue Apr 18 17:09:32 EDT 2006
Any ideas when a patch for this will be available?  The service is locking up
on my server several times a day and I have no way of knowing without
someone telling me or manually checking it.  At least I'm able to use some
of the tools from sysinternals.com to kill the service and restart it
remotely, but can't get it to restart automatically.  Even if I set the
recovery options in the service properties to "run a file" and point it to
my service restart batch file, that doesn't work.  Apparently Windows does
not detect that the service has died.  I'm pretty close to just running a
scheduled task to restart the service every 15 minutes, but that would kill
any current sessions.  Can anybody recommend any service monitoring software
that might work in this case?
Thanks,
Andy
Robert Bray wrote:
> Andy,
> We are currently tracking a regression bug that has these exact
> symptoms. Once we have tracked it down and are sure it's fixed, we'll
> try to post a patch of some sort. At this point I don't think it's worth
> you spending cycles on it, but we'll let you know if we do need some
> help.
> Thanks,
> Bob
>   _____
> From: Andy Morsell [mailto:amorsell at spatialgis.com]
> Sent: Friday, April 14, 2006 5:50 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] 1.0 Stability Problems
> Hi,
> I have been having problems with MapGuide Open Source Server locking up
> and ceasing to respond on a Windows 2000 Server that is using the .NET
> web extensions.  This has been happening about once a day.  When this
> does occur, the MapGuide service cannot be stopped and I have to use the
> kill command to kill the process and then restart the service.  The
> windows event logs aren't very helpful since most of the events are
> after it has locked up and are session errors (since the server is not
> responding).  The same with the MapGuide error and access logs - there
> is nothing obvious.  Are there any general, known stability issues at
> the moment or should I try to track this deeper?  Any ideas where I can
> get some clues about what is causing the problem?  This is the same
> server that has been running all the prior releases and RC1 was the most
> stable, with no restarts needed.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com <http://www.SpatialGIS.com>
View this message in context: http://www.nabble.com/1.0-Stability-Problems-t1452379.html#a3976800
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users mailing list
