[mapguide-users] RE: ODBC problem...
Andy Morsell amorsell at spatialgis.com
Tue Apr 18 20:22:10 EDT 2006
Here are the steps I took to create the join.  Note that I wasn't able to do
with anything with the join in terms of creating a layer from it, however.
*	Once your datasource is setup and you can see the tables listed in
the Refine Data Setup area, click the New Extended Feature Class button.
*	Choose your other datasource in the repository that you are
connecting to
*	Choose the Primary Feature class (table)
*	Click on your New Join below the Extension you just created
*	You will most likely only have one option for the Secondary class
(table)
*	Select your Primary Column and Secondary Column fields.  These are
the key fields tying together your primary (tabular) and secondary (spatial)
datasources.
If you get this far, please let us know if you can successfully create a
layer where you can view the resultant objects.  I also tried creating a
layer from X and Y points in a table from this database and, again, was not
able to view the resultant geometry.
Andy Morsell
-----Original Message-----
From: Thud732 [mailto:devlin.fung at sapience360.com]
Sent: Tuesday, April 18, 2006 4:30 PM
Subject: [mapguide-users] RE: ODBC problem...
Hi Andy:
Can you please outline your 'join connection' steps? I was able to establish
a successful test connection, but failed when joining.
Thank you.
TC
View this message in context:
http://www.nabble.com/Failed-to-test-the-Web-Server-Extensions-after-install
ation-t1432431.html#a3978903
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060418/b8f3b838/attachment.html
More information about the Mapguide-users mailing list
