[mapguide-users] Tiled map using GETMAPIMAGE
Traian Stanev traian.stanev at autodesk.com
Wed Apr 19 13:58:07 EDT 2006
And one additional comment... If you are compiling the server yourself
and willing to try new things, you can locate the function:
MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
                                                  MgSelection*
selection,
                                                  MgCoordinate* center,
                                                  double scale,
                                                  INT32 width,
                                                  INT32 height,
                                                  MgColor*
backgroundColor,
                                                  CREFSTRING format)
In ServerRenderingService.cpp around line 400 and in there change the
line:
    GDRenderer dr(width, height, bgcolor, true);
To
    GDRenderer dr(width, height, bgcolor, false);
This should make your GETMAPIMAGE generated tiles look a lot more like
the tiled AJAX viewer (GETTILEIMAGE) tiles at the expense of some
performance.
Traian
Sent: Wednesday, April 19, 2006 1:44 PM
Subject: RE: [mapguide-users] Tiled map using GETMAPIMAGE
Hi Velen,
Also, have in mind the comments I posted in the "Tiled Map" thread at:
http://www.nabble.com/RE%3A-MapAgent-parameters---Tiled-Map-p3783933.htm
l
Traian
Sent: Wednesday, April 19, 2006 1:26 PM
The AJAX viewer uses GETTILEIMAGE, so if you want your tiles to look the
same then that's the API you need to use.  GETMAPIMAGE was not designed
for use in a tiled context.
Walt
From: velen [mailto:vliang at thecarbonproject.com]
Sent: Wednesday, April 19, 2006 1:17 PM
Subject: [mapguide-users] Tiled map using GETMAPIMAGE
Hello,
We were able to generate tiled map using GETMAPIMAGE from a .net windows
form; below is the screen shot. As you can see, in the sample Sheboygan
map, some "District" numbers were chopped off in the same tile or showed
in the adjacent tiles. I understood this is probably because each tile
get rendered individually, but is there a solution for making tiles look
likes what ajaxviewer does?
Thanks for your help in advance,
Velen
More information about the Mapguide-users mailing list
