[mapguide-users] Loading an 8 GB SDF+ file
Bill Tenbroeck btenbroeck at itserve.com
Fri Apr 21 12:28:56 EDT 2006
That worked. Thanks!
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Friday, April 21, 2006 9:49 AM
Subject: RE: [mapguide-users] Loading an 8 GB SDF+ file
OK thanks. While we look at that, you can try the large file workaround
posted in the old archives at:
http://lists.mapserverfoundation.org/pipermail/mse-users/2006-January/00
0378.html
The explanation refers to a SHP file, but the same instructions should
work fine for an SDF+ file. Those instructions have worked for me for a
6 GB street network SDF file before, so they will likely for wor you...
as long as you don't preview your map before setting reasonable initial
view extents :-)
Traian
From: Bill Tenbroeck [mailto:btenbroeck at itserve.com]
Sent: Thursday, April 20, 2006 4:36 PM
Subject: FW: [mapguide-users] Loading an 8 GB SDF+ file
It fails trying to create the package in Studio
Sent: Thu 4/20/2006 10:38 AM
Do you already have the package copied to the server, or does it fail
when trying to create it in Studio?
Sent: Thursday, April 20, 2006 5:10 AM
Subject: [mapguide-users] Loading an 8 GB SDF+ file
I'm trying to create a package in Studio to load the TIGER Roads for the
US. The resultant SDF file is right at 8 GB. I have tried on 2 different
servers - both with lots of ram and disk space and I get the same error:
"Specified argument was out of the range of valid values. Parameter
Any one know of a setting that would affect this?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060421/9788a757/attachment.html
More information about the Mapguide-users mailing list
