[mapguide-users] Access database - Studio 2007 preview
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Apr 21 16:00:33 EDT 2006
The database is not local....but is on a mapped network drive (so it has
a fixed drive letter). The DSN is on my own development PC (which, like
I said, is working fine for my other webpages), as is MapGuide and
Studio. I also have about 4 other Autodesk products installed on my pc
(Land Desktop 2004, Raster Design 2004, Civil Design 2004, and Survey 2004).
In the end (once I finish the development) everything will end up on the
same server, and it will not have any other Autodesk apps installed.
Andrew
Jason Birch wrote:
> Are your Access database, the DSN, and the MapGuide Service all on the
> same computer?  Is Studio on the same computer as the MapGuide Service?
> Do you have any other Autodesk applications loaded on either the
> client or the server?
> Jason
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Friday, April 21, 2006 12:45
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Access database - Studio 2007 preview
> Ok, I've got the one from myfeedback installed now....still the same
> problem. Which suggests that there's something else going on here. My
> datasource works fine, because I'm using it in other vbscript
> webpages. There's got to be something that I'm missing here.....could
> it have anything to do with Studio needing some special ntfs permissions?
> Andrew
> Butler, Juan P wrote:
>> Access 2000.
>> Did you download it from the myfeedback site?  If not, try
>> downloading it from there.
>> - Juan
>> *Sent:* Friday, April 21, 2006 12:36 PM
>> Sounds like the same version I'm using....what type of database was
>> yours?
>> Andrew
>> I'm using version 1.0.0.16802.   Mapguide Studio 2007.
>> I downloaded it from the http://myfeedback.autodesk.com/ site.
>> - Juan
>> *From:* Andy Morsell [mailto:amorsell at spatialgis.com]
>> *Sent:* Friday, April 21, 2006 12:25 PM
>> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
>> *Subject:* RE: [mapguide-users] Access database - Studio 2007 preview
>> That was me using the Studio beta version rather than preview.  Juan,
>> I know you got this working, are you using the preview version of
>> Studio downloaded from the public web site?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> *Sent:* Friday, April 21, 2006 9:20 AM
>> I'm referring to one that I posted about maybe a week ago.....I can't
>> get any ODBC datasource to actually work in Studio....I see the
>> datasources fine, but never see a list of table / fields, and when I
>> test my connection, it fails. The concensus seemed to be that it was
>> the Studio Preview, because someone else did the exact same steps,
>> and it worked....the only difference was our Studio versions (his was
>> the full).
>> Andrew
>> Andrew,
>> Which ODBC problem are you referring to?   The two issues that I
>> brought up yesterday were the highlighting of a selection doesn't
>> work on a joined layer and the refresh issue.   Are these what you
>> are referring to?
>> - Juan
>> *Sent:* Friday, April 21, 2006 9:45 AM
>> *Subject:* [mapguide-users] Access database - Studio 2007 preview
>> I'm using Studio 2007 (preview) v1.0.0.16802.....Is the ODBC problem
>> to do with this version of Studio, or the OSGeo FDO Provider for
>> ODBC? I've got a project that I need to get done in 1 month, and am
>> trying to figure out if it's going to happen or not. With my current
>> setup, I can't get any of my Access ODBC datasources to work....no
>> one has suggested a workaround as of yet, so I'm starting to think
>> that it's just not going to happen. Does the solution have to come
>> from Autodesk (a new Studio version), or OSGeo (a new Provider? I
>> would tend to think that Autodesk would be slower than OSGeo, so
>> that's why I'm wondering.....Thanks.
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.506-453-1025
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> *Andrew DeMerchant*
>> ph.506-453-1025
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
>> *Andrew DeMerchant*
>> ph.506-453-1025
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> 	*Andrew DeMerchant*
> ph.506-453-1025
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
