[mapguide-users] Tiled map using GETMAPIMAGE
Jason Birch Jason.Birch at nanaimo.ca
Sat Apr 22 23:45:45 EDT 2006
Yes, it's a clearly stated requirement in the installation instructions.
I found that when I got ahead of myself and skipped this step that I had uninstall the web extensions, install .Net framework 2.0, and then re-install the web extensions.  A repair install after the 2.0 install may also have done the trick, but I didn't try that.
Jason
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Fri 2006-04-21 10:10 PM
Subject: Re: [mapguide-users] Tiled map using GETMAPIMAGE
No i'm In version Framework 1.1 .. is there any requirement to run this in framework 2.0?
Please inform me with some detailed help..
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
	You need to make sure that you are using .NET Framework 2.0.   Go into IIS and check to see if the virtual directory for the application is using 2.0.
	Juan Butler - Senior Programmer/Analyst
	GIS Applications
	Pinellas County Information Systems
	jpbutler at pinellascounty.org
	From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
	Sent: Friday, April 21, 2006 8:18 AM
	Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
	Source Error:
Line 16:
Line 17: <%@ Page language="c#" %>
Line 18: <%@ Import Namespace="
OSGeo.MapGuide" %>
Line 19: <!-- #Include File="utilityfunctions.aspx" -->
	On 4/19/06, velen < vliang at thecarbonproject.com <mailto:vliang at thecarbonproject.com> > wrote:
	Hello,
	We were able to generate tiled map using GETMAPIMAGE from a .net windows form; below is the screen shot. As you can see, in the sample Sheboygan map, some "District" numbers were chopped off in the same tile or showed in the adjacent tiles. I understood this is probably because each tile get rendered individually, but is there a solution for making tiles look likes what ajaxviewer does?
	Thanks for your help in advance,
	Velen
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060422/7590f522/attachment.bin
More information about the Mapguide-users mailing list
