[mapguide-users] problems with invoke URL
sukalyan chakraborty chakraborty.sarkar at gmail.com
Mon Apr 24 03:21:18 EDT 2006
Thank u so much ..For u'r help & reply me.
with a R&D i got it ...
I installed the MGStudio
& Mapguide Opensource
& the samples ..
But now the problem is same after installing framework 2.0 & installing the
MGOS
I'm starting again R&D on that matter ..
I'll inform u detailed problem on that matter in my next mail.
Thank U Again.
On 4/23/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
>  I think you are confused.   We are testing Mapguide Open Source which is
> a totally different version than Mapguide 6.x.   You should put the new
> version of Open Source on a machine that doesn't have previous versions of
> Mapguide.   You will need to download Mapguide Studio for your "map
> authoring" and data loads.
> Also, the .NET version of the Open Source install requires .NET framework
> 2.0.  This is the reson for your error.
> - Juan
>  *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* Sat 4/22/2006 1:06 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] problems with invoke URL
>  yes i'm using mapguide 6.5
> when i attempt to run it from
> http://localhost/mapguide/mapviewernet/ajaxviewerabout.aspx then get the
> error
>  *Compilation Error* *Description: *An error occurred during the
> compilation of a resource required to service this request. Please review
> the following specific error details and modify your source code
> appropriately.
> *Compiler Error Message: *CS0246: The type or namespace name 'OSGeo' could
> not be found (are you missing a using directive or an assembly reference?)
> *Source Error:*
>    Line 21: <%@ Import Namespace="System.Web" %>
> Line 22: <%@ Import Namespace="System.Globalization" %>Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>Line 24:
> Line 25: <!-- #Include File="common.aspx -->
> *Source File:* C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewerabout.aspx
>    *Line:* 23
> On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
> >  Are you using Mapguide 6.5?   Not sure why you would be posting here
> > for .mwf file.   The new Mapguide Open Source no longer uses this format.
> > If you are using Mapguide 6.5, just use Mapguide Author.
> > Juan Butler - Senior Programmer/Analyst
> > GIS Applications
> > Pinellas County Information Systems
> > jpbutler at pinellascounty.org
> > *From:* sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
> > *Sent:* Friday, April 21, 2006 6:57 AM
> > can u tell me please how can i create the .mwf file?
> > On 4/20/06, *shailesh* < shailesh at simplexindia.com> wrote:
> > hi all.
> > i have a problem with invoke url command, when i assign the URL TO OPEN
> > ..\dotnetviewersample\navigatetask.aspx
> > it shows me page cannot be dispalyed
> > however when i type
> > http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
> > in URL TO OPEN it works
> > i also tried something like c:\1.html after creating a file in C:\ even
> > that does not work
> > and also when i tested my application whihc is on the webserver
> > it tried typing the URL to invoke
> > http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was
> > unable to get
> > (i tried this because the localhost path was working onmy local machine)
> > need help on the correct way to write the URL to Invoke "
> > thanks
> > --------------------------------------------------------------------- To
> > unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
> > commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060424/f83c3659/attachment.html
More information about the Mapguide-users mailing list
