Editing MainFrame.templ
Kori Maleski km at pat.ca
Wed Apr 26 18:32:57 EDT 2006
And I should note that I have to do a FULL uninstall/reinstall of the web extensions to fix the crashes/buttons.
- which of course means I lose the edit I want to make...
Kori Maleski  BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
Sent: Wed 26/04/2006 3:26 PM
Subject: Editing MainFrame.templ
Hi all,
I need to call a javascript function from the OnSelectionChanged event in the mainframe.templ.
I had it configured in the RC 1.0 and it worked no problem.
I try to do the exact same thing in MGO 1.0 and I get constant DWF crashes along with all the buttons failing to appear on the tool bar (with a javascript error for each button).
Within the OnSelectionChanged I simply add a function call - ShowReport();
At the bottom of the the page I add the function -
ShowReport()
...harmless code here.
Can anyone identify why the error occurs in 1.0 and not RC 1.0?
Cheers,
Kori Maleski  BSc.
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Wed 26/04/2006 2:22 PM
Subject: RE: [mapguide-users] Any work being done on fixing MS IE KB912945
The artifact is included in the release notes:  https://www.osgeo.org/files/documents/12/71/releasenotes.html <https://www.osgeo.org/files/documents/12/71/releasenotes.html>
DWF Viewer 7 will be available soon.  Autodesk has a Beta you can sign up for (http://myfeedback.autodesk.com/) if you want to see a preview.
Sent: Wednesday, April 26, 2006 4:03 PM
Whoops.
Yeah, I looked for it and couldnt find it. Can you give me an Artifact ID?
Is there a release date for the next version of the DWF Viewer?
--Joel
Sent: Wednesday, April 26, 2006 12:48 PM
It's already been fixed in MapGuide.  There was an artifact (you can search for it :->).
The next release of DWF Viewer will also address this.
Walt
Sent: Wednesday, April 26, 2006 3:46 PM
Subject: [mapguide-users] Any work being done on fixing MS IE KB912945
Microsoft has deployed a "security" patch which forces you to "click to activate" any ActiveX control before you can use it. It is exceptionally annoying. Naturally, this affects the DWF Viewer.  It also affects the legend and property pane.  If you havent already dealt with it, you can see info about it here
http://www.microsoft.com/technet/security/advisory/912945.mspx <http://www.microsoft.com/technet/security/advisory/912945.mspx> . It is also worth looking at http://support.microsoft.com/kb/912945 <http://support.microsoft.com/kb/912945>
Has anyone looked at implementing the workaround? Can someone log this as an artifact?
--Joel
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060426/71a706ba/attachment.bin
More information about the Mapguide-users mailing list
