[mapguide-users] Can I get a clue?
Andy Morsell amorsell at spatialgis.com
Wed Apr 26 23:54:23 EDT 2006
If you hit the refresh button in your browser, does it load up without the
question marks?  I see the same thing about 1 out of 5 times when accessing
my site and refreshing the page usually forces it to load.  If you view a
web layout from Studio, will it load?  Or is this only happening with the
sample application?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
Sent: Wednesday, April 26, 2006 8:06 PM
Subject: [mapguide-users] Can I get a clue?
Ok, I'm stumped,  I can run
http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
And see the sample application but each of the layers has a "?" and doesn't
display anything in the map display area.
The admin page showed my sample data package was loaded..   ie I was able to
load the package without error.. Logs look ok.
However Studio will not get passed the default login page,  no matter what I
put in, it will not connect to the site.. I followed the getting started
guide and even reinstalled this, the odd part is it worked on a different PC
for me.
W2003 IIS6.
Any ideas, I have another ASP.Net application in a different application
pool running well on the same PC.  I followed the the install guide word 4
word but no luck.
Bill
Bill at PoconoGIS.com
www.PoconoGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060426/f716f522/attachment.html
More information about the Mapguide-users mailing list
