[mapguide-users] Mapguide Web Studio
Lockyer James James.Lockyer at bradford.nhs.uk
Tue Aug 1 12:25:31 EDT 2006
If you're on IIS you don't need the port number.
Note you may need to put index.html on the end of the reference depending on how your server has been set up.
Jim
Sent: Tue 01/08/2006 17:10
Subject: Re: [mapguide-users] Mapguide Web Studio
Michael,
According to newjim's post from a few days ago, you need to uninstall
the webserverextensions first before installing the 1.0.1 version.
See:
http://www.nabble.com/MapGuide-Open-Source-1.0.1-Released-tf2010637.html#a5543620
To answer your other question, Webstudio is a javascript and HTML
application that provides a subset of the Autodesk Mapguide Studio
application's functionality.
zak
On 8/1/06, Michael Pond <michael at infomine.com> wrote:
> Hello Mapguide users,
> I successfully set up mapguide ver. 1.0.0 , and used a few of the basic
> sample data sets etc.
> Today, I updated to the ver. 1.0.1 , and have begun to look at my sample
> data projects. I am also interested in the Mapguide Web Studio component as
> mentioned in the release notes: (a small portion copied here)
> MapGuide Open Source 1.0.1 Release Notes The MapGuide team is proud to
> announce the release of MapGuide Open Source 1.0.1. This release contains a
> significant number of bug fixes. All MapGuide Open Source 1.0.0 users are
> encouraged to upgrade to this release. This release is fully compatible with
> resources created using the MapGuide Open Source 1.0.0 release. If you
> uninstall the 1.0.0 release and then install this one in the same location
> your existing Resource Database will be preserved.
> This release includes the first version of MapGuide Web Studio. After
> installing try it out by opening this URL:
> http://localhost:8008/mapguide/webstudio (default location
> using the bundled install).
> I may be missing something fairly obvious, but I can not find any new
> feature for the Web Studio. In particular I have no page
> http://localhost/mapguide/webstudio (at either port 80 or
> 8008).
> Just to confirm, is this new component a web based tool that will more or
> less have the functionality of the desktop program from Adesk called
> "Autodesk MapGuide Studio preview"?
> Are there any specific instructions I should follow to install this feature?
> Thanks for your help.
> Sincerely,
> Michael Pond, P.Geo.
> Robertson GeoConsultants Inc.
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
This e-mail is intended for the use of the addressee only and may contain confidential information, copyright material or views/opinions that do not necessarily reflect those of the organisation. If you receive this email by mistake please advise the sender immediately. All should be aware that this email may be subject to public disclosure under the Freedom of Information Act 2000 and that emails may be monitored.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060801/be3ce508/attachment.bin
More information about the Mapguide-users mailing list
