[mapguide-users] Base Layers that are based on Oracle Spatial data
Robert Bray robert.bray at autodesk.com
Thu Aug 3 10:34:41 EDT 2006
Juan,
Tile Service has the following method:
virtual void
ClearCache
<file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\
df\dba\class_mg_tile_service_16adf9e13f5acc6439571b348180265e.html#16adf
9e13f5acc6439571b348180265e>  (MgMap
da\df8\class_mg_map.html>  *map)=0
Clears the entire tile cache for the given map. Tiles for all base map
layer groups and finite scales will be removed.
df\dba\class_mg_tile_service.html#16adf9e13f5acc6439571b348180265e#16adf
All you need is a little PHP script that connects to the server and
calls this method. Then schedule to run that script once a week, once a
month, or on whatever schedule you feel appropriate. For an example of
how to write such a thing, look in the RepositoryAdmin folder that lives
underneath the server install folder.
Bob
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Thursday, August 03, 2006 8:09 AM
Subject: RE: [mapguide-users] Base Layers that are based on Oracle
Spatial data
Exactly Jason...Like our road layers.   I'm not saying there are many
updates but there enough updates to be worried about the correct data
being displayed.   I was seeing a benefit of using the tiles for our
roads because of the high use of this layer.
I guess I have my answer and I'll have to either not use tiles at all or
just manually delete them so they can be rebuilt.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is
subject to the Public Records Law of Florida.
  _____
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thu 8/3/2006 9:07 AM
Spatial data
Yes, I imagine there is a point at which base layers make more sense in,
like you say, high levels of usage.
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, August 02, 2006 11:19 PM
Spatial data
I don't have much experience with tile caching and the new MapGuide, but
if the data is only being updated once per day or once every few days,
and you have high levels of usage on your web app, I'd have to believe
that you would get some kind of performance return from only having to
render those layers when they are actually modified...  Hmm.  I think
that was a run-on-sentence.
Jason
  _____
Sent: Wed 2006-08-02 8:10 PM
Spatial data
If the layer will be changing a lot, is there any point for it to be a
base layer at all? Just make it a regular dynamic layer...
	-----Original Message-----
	Sent: Wed 8/2/2006 10:12 PM
	Cc:
Oracle Spatial data
	It would be useful to set a property on the layer like
InvalidateDate that would force tile-replacement for tiles that are
older than that date.  If this feature was available, it would be
possible to set up a trigger in Oracle to invalidate the tile cache for
affected layers.  I'd prefer this method to just deleting the cache,
because of the huge file IO caused by the delete, and because it would
reduce fragmentation of the volume.  This would be usable by other
external processes, such as daily SDF updates via FME, etc...
	Jason
  _____
	Sent: Wed 2006-08-02 4:42 PM
	To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Oracle Spatial data
	As far as I understand it, only changes to the layer or map
definitions will be detected. For example change in the styling for the
layer. Changes to the actual data in Oracle will not be detected.
	Traian
		Sent: Wed 8/2/2006 5:36 PM
		Cc:
		Well, I've been told that Enterprise handles the changes
to data that is stored in the repositories.  From my understanding, data
that is changed in the repositories will be marked in someway so that
the tiles can be rebuilt as needed.    Can someone from Autodesk please
clarify this?
		GIS Applications
Government is subject to the Public Records Law of Florida.
  _____
		From: Andy Morsell [mailto:amorsell at spatialgis.com]
		Sent: Wednesday, August 02, 2006 5:30 PM
		My understanding of the current functionality of base
layers is that they don't update themselves based on an underlying data
change regardless of the source data type.  This would be up to you to
delete the images from your TileCache directory to force them to rebuild
the next time somebody viewed that map area.
		Andy Morsell, P.E.
		Spatial Integrators, Inc.
		http://www.SpatialGIS.com
  _____
		Sent: Wednesday, August 02, 2006 2:02 PM
		Subject: [mapguide-users] Base Layers that are based on
Oracle Spatial data
		Does anyone at Autodesk (or anyone that has tested it
already) know if I use Oracle Spatial data for my base layers, will
Mapguide Enterprise know about the changes and update the tiles
accordingly?   I'm in the process of testing this and just wanted to
know if anyone has had any experience with it.
		Thanks.
		GIS Applications
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060803/919ba4ee/attachment.html
More information about the Mapguide-users mailing list
