[mapguide-users] Base Layers that are based on Oracle Spatial data
Butler, Juan P jpbutler at co.pinellas.fl.us
Thu Aug 3 10:09:06 EDT 2006
Exactly Jason...Like our road layers.   I'm not saying there are many updates but there enough updates to be worried about the correct data being displayed.   I was seeing a benefit of using the tiles for our roads because of the high use of this layer.
I guess I have my answer and I'll have to either not use tiles at all or just manually delete them so they can be rebuilt.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject to the Public Records Law of Florida.
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thu 8/3/2006 9:07 AM
Subject: RE: [mapguide-users] Base Layers that are based on Oracle Spatial data
Yes, I imagine there is a point at which base layers make more sense in, like you say, high levels of usage.
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, August 02, 2006 11:19 PM
I don't have much experience with tile caching and the new MapGuide, but if the data is only being updated once per day or once every few days, and you have high levels of usage on your web app, I'd have to believe that you would get some kind of performance return from only having to render those layers when they are actually modified...  Hmm.  I think that was a run-on-sentence.
Jason
Sent: Wed 2006-08-02 8:10 PM
If the layer will be changing a lot, is there any point for it to be a base layer at all? Just make it a regular dynamic layer...
	-----Original Message-----
	Sent: Wed 8/2/2006 10:12 PM
	Cc:
	It would be useful to set a property on the layer like InvalidateDate that would force tile-replacement for tiles that are older than that date.  If this feature was available, it would be possible to set up a trigger in Oracle to invalidate the tile cache for affected layers.  I'd prefer this method to just deleting the cache, because of the huge file IO caused by the delete, and because it would reduce fragmentation of the volume.  This would be usable by other external processes, such as daily SDF updates via FME, etc...
	Jason
	Sent: Wed 2006-08-02 4:42 PM
	To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
	As far as I understand it, only changes to the layer or map definitions will be detected. For example change in the styling for the layer. Changes to the actual data in Oracle will not be detected.
	Traian
		From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
		Sent: Wed 8/2/2006 5:36 PM
		Cc:
		Well, I've been told that Enterprise handles the changes to data that is stored in the repositories.  From my understanding, data that is changed in the repositories will be marked in someway so that the tiles can be rebuilt as needed.    Can someone from Autodesk please clarify this?
		GIS Applications
		From: Andy Morsell [mailto:amorsell at spatialgis.com]
		Sent: Wednesday, August 02, 2006 5:30 PM
		My understanding of the current functionality of base layers is that they don't update themselves based on an underlying data change regardless of the source data type.  This would be up to you to delete the images from your TileCache directory to force them to rebuild the next time somebody viewed that map area.
		Andy Morsell, P.E.
		Spatial Integrators, Inc.
		http://www.SpatialGIS.com
		Sent: Wednesday, August 02, 2006 2:02 PM
		Subject: [mapguide-users] Base Layers that are based on Oracle Spatial data
		Does anyone at Autodesk (or anyone that has tested it already) know if I use Oracle Spatial data for my base layers, will Mapguide Enterprise know about the changes and update the tiles accordingly?   I'm in the process of testing this and just wanted to know if anyone has had any experience with it.
		Thanks.
		GIS Applications
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060803/2f81fe43/attachment.html
More information about the Mapguide-users mailing list
