[mapguide-users] Postgres + OGRProvider.dll = big problem.
Andy Morsell amorsell at spatialgis.com
Thu Aug 3 12:03:56 EDT 2006
This constraint can be partially worked around by editing the IIS Metabase.
For those interested in getting under the hood, you can download the
Metabase editor from here: http://support.microsoft.com/kb/232068.  Then,
change the LM\W3SVC\MaxConnections value from 10 to 40.  Note that setting
it above 40 will not help.  In my experience on my Windows XP SP2
development box using MapGuide Open with the .NET web extensions and the
AJAX viewer almost exclusively, I have never had a problem after doing this
fix 8 months ago.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, August 03, 2006 6:04 AM
Subject: RE: [mapguide-users] Postgres + OGRProvider.dll = big problem.
One issue to look out for when using XP and IIS is the simultaneous
connection limit that IIS for XP has. Other than that it works fine on XP.
From: Bogdan Modzelewski [mailto:Bogdan.Modzelewski at procad.pl]
Sent: Thursday, August 03, 2006 1:50 AM
Subject: Re: [mapguide-users] Postgres + OGRProvider.dll = big problem.
> "I have install on my laptop (XP+SP2)" --> you have to use win2k or
> win2k3 to get a fine working mapguide server. I cannot run it right
> mapguide server on xp, too.
That's not true. I've managed to run MG (all versions including
enterprise) in the same environment (XP SP2) without any problems.
I've just installed it and it runs out of the box.
Best Regards,
Bogdan Modzelewski
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
