[mapguide-users] Base Layers that are based on Oracle Spatial data
Butler, Juan P jpbutler at co.pinellas.fl.us
Thu Aug 3 12:40:19 EDT 2006
Jason:
You think there is that much of a problem with fragmentation?   We do a similar process now with picture/data files where we delete them.  We do this because of the older system we are migrating from.  I was hoping that I would not have to do this with Enterprise, but it's not that big of a deal if I can just automate it.  I don't see an IO hit or fragmentation problem now.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject to the Public Records Law of Florida.
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Thu 8/3/2006 12:20 PM
Subject: RE: [mapguide-users] Base Layers that are based on Oracle Spatial data
Bob,
Does that method actually delete all the files in the cache, or just mark them as stale?
I'd be worried about the IO hit and volume fragmentation resulting from a bulk delete.  It would be better if the server would overwrite existing tiles with modified dates < the date the cache was last invalidated.
Jason
From: Robert Bray [mailto:robert.bray at autodesk.com]
Sent: Thursday, August 03, 2006 07:35
To: Butler, Juan P; users at mapguide.osgeo.org
Juan,
Tile Service has the following method:
virtual void
ClearCache <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\df\dba\class_mg_tile_service_16adf9e13f5acc6439571b348180265e.html#16adf9e13f5acc6439571b348180265e>  (MgMap <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\da\df8\class_mg_map.html>  *map)=0
Clears the entire tile cache for the given map. Tiles for all base map layer groups and finite scales will be removed. <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\df\dba\class_mg_tile_service.html#16adf9e13f5acc6439571b348180265e#16adf9e13f5acc6439571b348180265e>
All you need is a little PHP script that connects to the server and calls this method. Then schedule to run that script once a week, once a month, or on whatever schedule you feel appropriate. For an example of how to write such a thing, look in the RepositoryAdmin folder that lives underneath the server install folder.
Bob
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Thursday, August 03, 2006 8:09 AM
Exactly Jason...Like our road layers.   I'm not saying there are many updates but there enough updates to be worried about the correct data being displayed.   I was seeing a benefit of using the tiles for our roads because of the high use of this layer.
I guess I have my answer and I'll have to either not use tiles at all or just manually delete them so they can be rebuilt.
GIS Applications
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thu 8/3/2006 9:07 AM
Yes, I imagine there is a point at which base layers make more sense in, like you say, high levels of usage.
Sent: Wednesday, August 02, 2006 11:19 PM
I don't have much experience with tile caching and the new MapGuide, but if the data is only being updated once per day or once every few days, and you have high levels of usage on your web app, I'd have to believe that you would get some kind of performance return from only having to render those layers when they are actually modified...  Hmm.  I think that was a run-on-sentence.
Jason
Sent: Wed 2006-08-02 8:10 PM
If the layer will be changing a lot, is there any point for it to be a base layer at all? Just make it a regular dynamic layer...
	-----Original Message-----
	Sent: Wed 8/2/2006 10:12 PM
	Cc:
	It would be useful to set a property on the layer like InvalidateDate that would force tile-replacement for tiles that are older than that date.  If this feature was available, it would be possible to set up a trigger in Oracle to invalidate the tile cache for affected layers.  I'd prefer this method to just deleting the cache, because of the huge file IO caused by the delete, and because it would reduce fragmentation of the volume.  This would be usable by other external processes, such as daily SDF updates via FME, etc...
	Jason
	Sent: Wed 2006-08-02 4:42 PM
	To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
	As far as I understand it, only changes to the layer or map definitions will be detected. For example change in the styling for the layer. Changes to the actual data in Oracle will not be detected.
	Traian
		Sent: Wed 8/2/2006 5:36 PM
		Cc:
		Well, I've been told that Enterprise handles the changes to data that is stored in the repositories.  From my understanding, data that is changed in the repositories will be marked in someway so that the tiles can be rebuilt as needed.    Can someone from Autodesk please clarify this?
		GIS Applications
		From: Andy Morsell [mailto:amorsell at spatialgis.com]
		Sent: Wednesday, August 02, 2006 5:30 PM
		My understanding of the current functionality of base layers is that they don't update themselves based on an underlying data change regardless of the source data type.  This would be up to you to delete the images from your TileCache directory to force them to rebuild the next time somebody viewed that map area.
		Andy Morsell, P.E.
		Spatial Integrators, Inc.
		http://www.SpatialGIS.com
		Sent: Wednesday, August 02, 2006 2:02 PM
		Subject: [mapguide-users] Base Layers that are based on Oracle Spatial data
		Does anyone at Autodesk (or anyone that has tested it already) know if I use Oracle Spatial data for my base layers, will Mapguide Enterprise know about the changes and update the tiles accordingly?   I'm in the process of testing this and just wanted to know if anyone has had any experience with it.
		Thanks.
		GIS Applications
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060803/8a24433b/attachment.html
More information about the Mapguide-users mailing list
